crazy-in-az
Uhhhh....
I would clean the relay. My JVC JR-S400 mkII did the same thing yours is doing. I solved the problem by removing the little plastic cover over the relay. I sprayed a few thin strips of paper (about 1/8th inch x 4 inches) with contact cleaner, and with the unit off, and the volume turned all the way down, I slid the paper between the contact points. Turn the receiver back on so that the two points make contact (with the paper between them), then slide the paper out. Do this 3 or four times with all contacts.
I hope that makes sense and you get your Scott up and running again!
