002
Hi all,
I have a Luxman A-373 with the symptom described in the thread title; powers on but no sound at all. I have ruled out what I presume to be the obvious things first - tested A and B speakers, tested various inputs.
There only seems to be one fuse in the entire amp which is on the power supply board - is that normal for amps of this era (~1995)? I've tested the voltage regulators on the power supply board (a 7805 and 7812) and they seem to be working. I can't find a schematic or service manual anywhere so I guess it will be tough to diagnose.
The main output transistors appear to be C3856 NPN and A1492 PNP. I've tested them in circuit and they seem to be OK so I am at bit of a loss. All the electrolytics in the unit are ELNA brand and seem very healthy.
Does this sound like a power supply problem? One thing I noticed is that there's a 3-wire cable that runs from the PS board to the board with the output transistors on it and the voltages on that wire are +12V, 0V, and -33V. I thought that the -33V seems a bit suspicious but I don't know if that's normal either.
Naturally I am happy to provide pictures or any other requested info. Thanks in advance!
