hi all, I purchased a non working Luxman l-100 in pretty good condition, I’ve started to refurb it but hoping to get some help where to look next to solve the faulty right channel so far can confirm
- both amp modules are working well when used directly as a power smp
- bias and offset holds ok
- power supply voltages at c07-10 look good approx 57v
- right channel when used as a integrated is low and distorted
- Both channels have hum regardless of volume level and regardless if pre-main in out links are connected - the hum doesn’t get louder or softer with volume adjustment.
So far I have recapped the unit, replaced the vd1221 diodes with pairs of 1n4148, replaced zeners and replaced all the 2sc1345 with bc550c
Relay clicks out of protection
I see no broken grounds or cables or bad joints any pointers where I can look next?? Thankyou
