Hello, A few months ago I retrieved my Luxman l-80v from storage. After connecting it up it started humming aggressively so I turned it off and let it rest for a bit. On the second attempt, the humming grew and the old 50v 10000uf Capacitors exploded. All 3 of the 0.3A 250v 6x30mm fuses were blown so I replaced them and the system turned on but no sound. So I ordered replacement capacitors and waited for them to arrive. I wired them up today and after wiring them up on the first attempt I heard the relay click and to my suprise the amplifier worked and played for a few minutes until the 125v 5a fuse burst into a green spark and one of the new caps smelt a bit and looked as if it had expanded a bit but was still intact however to note this capacitor was the only one that was hot out of the two. After this I replaced the 125v 5a with the only replacement I had on hand which according to online sources would be alright to replace with a 250v 5a fuse. After letting the amp rest I powered it on and sounded like it was shorting so I immediately turned it off on the second attempt I replaced the capacitor grounding rod with a wire and this time the new capacitiors blew again . Hopefully someone can help and also to add ive noticed the relay is now a bit cloudy but im not sure if this was already like this previously as I heard it clicking.
