david winter
Classical music lover.
Hi,
This amp uses longer fuse lamps of 45mm.
As 41mm ones also fit, I wanted to know if someone used the common 6.3V fuse lamp. This one shows a 270 ohms resistor on the bottom side of the pcb, so I wondered if replacing it with a 430 ohms (or so) would do the trick.
Or whether there is a 10V model selling at reasonable price.
Thanks !
Thanks !
