Hi all,
I’m dealing with an anti-skating issue on my Luxman PD-264. No matter how I adjust the dial (I’ve turned it fully each way), the tonearm consistently pulls toward the center. I see that the anti-skating dial pivots a thin rod underneath. The rod stretches from its pivot point into the tonearm housing, and with the turn of the dial, it moves back and forth (left and right) in there. But I have no idea what it’s engaging with—possibly magnets that have become dislodged or lost their strength? (Or a spring?)
Everything else, including the auto-lift, works perfectly and is calibrated.
The manuals I’ve found online don’t indicate anything about how the anti-skating functions or provide troubleshooting methods, and I can’t find any discussions or videos online.
If anyone has successfully repaired the anti-skating on this type of model or similar, or has the knowledge, I'd be grateful for your help! And if I need to take apart the tonearm housing (as I suspect), what level of difficulty will I face? What should I look out for, and what parts might be affected? Do I need to go into the housing down from the top or up from underneath?
Any insight would be much appreciated so I can get this guy up and running right! Any info I need to give or photos/videos need--please let me know.
Thanks again kindly!
Tripp
Tripp
