Luxman PX-100 Redux!
jleon92f
Addicted Member
Hi Vinyl fans,
It has been a few weeks since I finished the luxman PX-100, she sounds awesome! Playing Al Di Meola "Elegant Gypsy"
Thanks,
John.:music::D
Looks like a winner John! What did you have to do with it?
Just put my Luxman PD-277 back in rotation and it's playing nicely. I've found that changes to VTA can throw the auto functions out of alignment (lead-in, lead-out) if I'm not very careful with arm alignment on the plinth. Otherwise it's a tank!
BTW, Elegant Gypsy is a killer album. Romantic Warrior is another one in the same genre.
Jim
Jim
Your PD-277 is Very Nice! I did a recap on the PSB and the Motor PCB, lube the main bearing also. Clean up the whole unit, very dirty.
Thanks,
John.:music::D
And one number up from the PX-100 is this, the PX-101
Seller said it did not work, it just needed a good cleaning and a lube job and it´s playing again. still working on the cover, polishing it.
Properly is, as far as i know, all Luxman TT´s are made by other brands. Here are some night shots (it´s almost midnight here) of the newly polished cover and TT playing Scorpions Lovedrive (yes the xrated cover with the girl and the bubblegum!)
By the way, how do I post big pics.?
If you have your pictures saved on a website you can paste the web address to your post with these characters surrounding it:
If your pics are saved on your computer you'll need to set up a account with photobucket.com or picasa.com or any other free photo hosting website and then paste them into your post here.
John,
how did you lube the main bearing? I can't see any opening to do so on my table.
Jim
Thanks for the link John, it's apparent from your pics that they used a completely different motor in the PD277. If I ever have rumble issues I may have to take a drill to mine, just not yet!
After I drilled the hole I could remove the spindle, then I oiled it up and glued the hole off with epoxy to keep the oil in, reinstalled the spindle. Next time I am installing an oil tube. You may not have to drill a hole in the bearing, check to see if the spindle comes out 1st.
Thanks,
John.:music::D
