Luxman R-1050 one channel not working
That is just weird. Maybe some bad connections in the fuse holders from having the fuses in for so long, corrosion or whatever.
Don't know what 4 fuses you finally used but glad it's working.
Update
Drove all around my area to all the electronic stores and finally found a repair shop that had the right fuse.
Bought one brought it home. Looked identical to the Amazon fuses.
Powered on the Luxman with no turntable or speakers hooked up. The unit would stay in a consent blink never fully powering on.
Powered off and unplugged the unit and switched to a different new fuse. Same results.
Powered off and unplugged the luxman. Put the old fuse back in. Powered on the unit and it would fully power up with only the one channel working
Powered off and unplugged the unit.
Had a smoke or two and did some serious head scratching.
Decided to replace all 4 fuses that are on the board.
Powered on the unit and Abra cadabra the unit powered on successfully.
Hooked up speakers and turntable. Ran it through its paces and everything is working just fine. Sounds wonderful.
Thanks to everyone who chimed in to help me .
Tell next time. And there will be a next time.
Jack
One of the other fuses was probably blown. They can look good and be blown. Always check with a meter.
One of the other fuses was probably blown. Always check with a meter.
Happens all too often. repeated, jack up in size and bolded so folks see it and do it.
