So I was looking at Fleebay last week and 2 R-117's showed up...I was at the Right Time looking around as to 1min into the listings with Buy-It-Now...
1st R-117 for 125 Buy-It-Now. Right channel not working.
2nd R-117 for 100 Buy-It-Now. Not powering on.
1st R-117 the Right channel Power Board Molex cable not attached. The Outputs had been replaced...Looking at the board some resistors burnt.
2nd R-117 the Main fuse is blowing...Tracked it down to Left Power Board starts to burn a resistor. So I remove the Left PB Molex cable, install a New fuse and
from Right Channel.
The Pictures are from the 1st R-117...Took the 2nd unit Right Channel PB and put into the 1st R-117.....A nice DeoxIT on the switches, Adjust Idle Current and ALL is Working!!!!
Since I have a R-117(Mint) and now a 2nd R-117...The other R-117 is now a Parts Unit.
For the price of the Both listings..The was a no brainer to take a chance.
Putting together a Cap list....
from Right Channel.The Pictures are from the 1st R-117...Took the 2nd unit Right Channel PB and put into the 1st R-117.....A nice DeoxIT on the switches, Adjust Idle Current and ALL is Working!!!!
