Let's continue on the KX-102 Restore.
Now, it's been taking me a lot longer to do this restore than I thought, and it's not because I've been working hard on it. Rather, the unit has been apart collecting dust and I've been just waiting on all the parts to show up that I ordered. I've had to buy a lot of parts from Germany, China, and the UK.
- Purchased a special belt kit from Amazon that has exact fit suck face belt and cassette belts.
- Purchased a replacement custom idler tire from Germany (take up reel slipped).
- Bought special non-polar nichicon MUSE green capacitors for all bipolar caps from the UK.
- Had to get some of the Nichicon Fine Golds from China. (Checked for correct capacitance and authenticity)
- Ordered the usual standard value caps from Mouser.
- Ordered a new micro switch for the suck face.
So, it's taken a long time and still some of the caps are in transit. I'm throwing a ton of parts at this thing, hoping to see the creaks, squeaks, and little issues disappear.
But, I really want the suck face to work on this deck, and I decided to purchase a belt kit that included the right thickness and diameter of belt. My problem with the suck face was that it made an abnormal howling noise and sometimes it was too weak to suck in or recoil back when powered down. The noise alone was enough to make me disable it. But, I decided to do a full rebuild of it and took it apart again and replaced my generic belt with a custom part:
View attachment 3432252View attachment 3432253
As you can see, the new belt is a perfect fit, and has good stretchiness to it. I used this Amazon kit sold by Bob's Vintage Audio Parts:
Buy Complete Belt Kit for Luxman KX-102: Timing Belt Kits - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
a.co
Anyways, I put some grease around the cam/planet gears to hopefully stop the noise, and reassembled the mechanism... unfortunately, I did what many others have done, I broke the micro switch:
This switch is tiny, measuring only 12mm long. One of the poles broke off, and I wasn't even being that rough with it. I was gutted initially, because I had already read of folks having a difficult time sourcing a replacement. I did find one that worked ok, it was the OMRON D2HW-C221H. It is available from Mouser.
It's a good bit bigger than the original... maybe 20% longer, and it's 5.3mm thick instead of the 3mm of the original. Now. It will not fit in between the cam and the assembly unless you Dremel off the peg facing the side of the cam and also shorten the metal arm to be flush with the edge of the switch case. Finally, the screw hole is much too big, but you can jam the entire screw head in the hole tightly, and then I made a little metal stabilizer that screws to the case which I attached onto the other peg I didn't have to Dremel. This stabilized the switch very well. I don't have any photos of this... can't really take any to show the process due to the size. In this photo, I had tried to use epoxy to hold it in place, of course it didn't work reliably... I am showing the metal addon I made in the video down below.
Anyways, you can see how it fits... barely. With the screw head jammed in the switch's hole and screwed halfway through, and the epoxy added, it doesn't scrap or cause any undesired effect. I added the metal piece instead of the epoxy in the video below. Pardon the rotten soldering job on those wires... The wiring on the switch is different from the original, so I had to do some wire swapping a lot to get it right. I made it neat in the end. I think overall, you can't really find a replacement switch for this mechanism, but if you don't mind doing something that's a little unorthodox, this is a reliable fix that borderlines on Jerry rigging. So, with this, the suck face is operational and quiet... but is still weak.
Let's end this post with some caps. I had the parts to recap the control board, and some of the VFD board:
View attachment 3432281View attachment 3432282View attachment 3432283
See the big caps in the lower right? Those are for the suck face motor circuit. When I replaced these, the speed and power on the suck face rose dramatically, to where it easily sucks in and recoils very quickly. Feels exactly how it should. Here's a video:
No board left behind! Even these little boards have a few caps, and they need replacement just like the main board. This board was tough to reach; the entire suck face had to be dismantled, then the metal frame attached to the 'sucker' that houses the tape counter and VFD has to come apart too.
Next post, the main board will be done, and I'll have better pictures of a summary of all the work done... It's a lot.
