Blue Shadow
Waiting for Vintage Gear from this century
Well the receiver is up and running. Seems an o-ring is too thick to replace the belt for the servo face so I'll order the belt eventually. I have the face pulled back and dialed in the offset and idle. There was no need to adjust the offset but the idle was close to 1-2mV and spec is 14±5 which it is now.
I also adjusted the fluorescent power indicator. The amp did not have equal gain with 28V on one channel and 26.5V on the other with a split 1kHz signal going into AUX. Seems the balance is off a bit or the output level is not quite what is reported.
This is a fairly limited flexibility-wise receiver. I have it warming up on a pair of Magneplanar MG-IIIa speakers and it handles them just fine to the power limit. Sounds good, too.
I understand the issues with the wobbly controls. There are plastic shafts to the pots a few inches behind the faceplate and that contributes to the flimsy feeling.
The remote is odd, too. A nice rectangular unit with nothing in the way of ergonomic shaping. There is no movement of the volume control or an indicator on the receiver of the muting being on or off. The receiver does have an on-off switch for the remote and the volume set on the receiver is the volume that the remote has to work with as it adjust up and down. Early wireless I guess.
A couple issues with this unit are the broken Speaker A switch which will not stay in and the lamp that illuminates the buttons from below is out. Any hints for these repairs, switch or lamp* to use would be greatly appreciated.
*Found the lamp on the schematic and it is 12V probably the same as many Luxman units used. I should have one of these.
