Any issues with the amp board?I've been very impressed with the m&k 2vb sub & sat setups. The 2sbs kind of remind me of ads speakers. And the 2vb is the subwoofer that I still use most for my everyday listening. As far as powerful home theater subwoofers there are many better than the 2vb, but for a subtle and musical subwoofer that blends incredibly well in a stereo setup the 2vb fits the bill.
I have a chance to pick up a set of what I believe are S2Bs paired with a V2B sub. All Trapezoidal. I think they're in good shape other than the sub needing foam. $70-$80 should get them.
I'd either flip or keep. Could make a nice 2.1 video setup.
-Carl
Yeah makes sense. Reason why it was thrown out rather than the bad foam. I'll mess around some more and maybe pull the amp and take some voltages. I'd like to fix as this will be used for 2 ch listening. I'd like to know more about why they're tough to service as I've gleaned from a few internet mentions.By your description, it sounds like a plate amp looking to cross the Rubicon.
I'll catch hell for saying this, but plate amps are such crap. For every one regular power amp failure I know of, I've heard of 10 subwoofer plate amp issues. It doesn't take Bob Carver's smarter brother to simply look at the construction differences between the two to know which one will have the shorter lifespan. Some say life behind a big thumping driver is not conducive to longevity either.
If you've got a preamp or HT receiver with good subwoofer control, a $50 Kenwood power amp off of Craigslist would do the job better and longer.
If I had a photo of Porkloin Plate Amp Generation 1 from the inside, it would pretty much look like it does on the outside - four posts and two fuse holders.
Can you get a better shot of the satellite backs, the part above the "SEE INSTRUCTIONS"? M&K sats had two sets of jacks on the back, but they were not intended to be used simultaneously; they were used to connect to different points on the crossover. How do you have the wires from your amplifier run?Think I might've been wrong about the speaker not being source of noise. Used signal generator to test. No rubbing on voice coil but a still a vc issue. I unplugged one of the leads (dual vcs) and the noise pretty much went away. If I cranked it I'd get some crackle buzz. It's probably a sure sign of ________ but I don't know what I'm looking at.
Speaker shows 4 ohm at both terminals. The amp hum reduced without speaker connected.
