Hi,
You can remove the entire front glass assembly by taking out the three screws on each side of the amp that are about 1 inch from the front. Unless you're changing the glass, you shouldn't need to take out the small screws on the shiny end caps.
As for the knobs, they're pressure fit. It's really hard to pull them off, but they do pull off. I thought I was going to break mine.
The lamps are bayonet base, so they theoretically press in and rotate 30-45 degrees. On mine, the main illumination bulbs came out fairly easily, while the indicator bulbs were virtually impossible. I broke the glass on a couple of them and used needle nosed pliers to get the bases out. Fortunately, putting them back in was much easier. Hopefully someone with a better experience can say what I did wrong.
One other thing to note. I noticed that the two outside main bulbs had some play in depth after they were seated properly. Pulling them as far out of the front as possible before installing the glass made the glass brighter. I haven't taken pictures yet, but I can see where the socket has a spring clip and can move in and out about 1/8".
