Matt The Cat
Prowlin' At 78 RPMs
Hi,
I'm stumped and I really could use some advice on how to fix possible RF, EMF or grounding issues on the phono stage of my MA2275.
It was just in the shop for 2 blown transistors controlling the bias of one of the KT88s. That issue was fixed, but as soon as I hooked it up, I noticed a much increased noise floor on the phono stage, V4 and V5 on this amp. I have tried a variety of remedies to try and bring this interference down. I've recorded the noise with my cell phone to show how loud it is and what it sounds like. Here is a link to the 5 secs of the phono stage interference.
http://www.mattthecat.com/MacPhonoDistortion.wav
The phono stage sounds fine, except for the interference. All line level inputs are perfectly quiet. The turntable is grounded and the interference doesn't change AT ALL when the turntable is disconnected. I've used shorting cables and they bring the interference down slightly. Thinking it might be a grounding issue, I've taken out the grounding pin on the amp, I've moved both the amp and the turntable to the same circuit...then moved them to different circuits. NO CHANGE AT ALL. I've upgraded my power strip to a Furman PS8 to try and clean up my AC. NO CHANGE AT ALL.
THE TUBES: I've changed out the tubes in V4 and V5 many times and found NO CHANGE. I bought some tube shields and installed them. They seemed to make things worse. When I touch the tube in V4, the interference becomes MUCH worse with more static. Then when I separately touch the tube in V5, a loud hum is introduced. This happens the same on every 12ax7 that I have tried. Touching the ax7s in the line level section has no affect on anything.
I've talked to the McIntosh certified tech who worked on the amp about this and he assures me that he didn't do anything while he was inside the amp. He said that by working on the transistors under a power tube, he didn't mess with anything in the phono section. He said the boards are completely separate and there is no grounding in there to mess with. Can anyone else confirm that there isn't a simple grounding fix within the amp?
The 2275 is not located near a TV, antenna or wifi router. I've unplugged the only light dimmer in the room. I've shut down all computer equipment and baby monitors. I can't for the life of me figure out how to solve this problem.
Please let me know if you have any ideas or can comment on possible grounding issues in the phono stage itself. Is there anything I haven't tried? This is starting to drive me crazy.
Thanks so much!
Matt
Salem, MA
Thanks so much!
Matt
Salem, MA
