MAC 1900 balance issue!
KentTeffeteller
Gimpus Stereophilus!
Hi all,
My beloved old McIntosh MAC 1900 has reduced volume and some cutting out when the balance pot is centered? Am I looking at needing a balance pot replacement? I am curious of solutions. Terry D, any ideas? :tresbon:
Kent, seems to me that it used a similar pot to the C28. Terry should be able to confirm or not on that.
To confirm, however, is the imbalance consistent across the whole volume control arc? If so, then there's other problems than the volume pot. I'd doubt the balance control, though. I'd be looking for mechanical things like dirty switches/contacts, etc.
Cheers,
David
Hey Kent now you are on my side electronic Alantic.
Years ago I had a MAC1900 that was driving me nuts. Customer's unit would intermitantly lose volume level when the balance was centered but gain level when rotated toward left or righr balance. Did I say it was intermitant!!!!
Turns out there is under the power supply board a chassis ground for the speaker system switching and when the rivit, washer, chassis gets corroded the amp tries to seek ground through the other channel, causing both channels to attenuate. Once you imbalance the channels the volume would go up abeit skewed to one side. The unit I had would choose to conduct in varying degrees it seemed based on the humidity.
Most problems besides tranistor failure on these older units have always been grounding and sheild issues.
c dk,
Thanks for that tip. I will check this one today and see if it cures this issue. I was thinking that it was something minor like this.
c dk,
I think you can get at the drain at the speaker selector board for a try jumper. To get at the actual ground rivit is a bit of a royal pain.
Good hint. This (better grounding) can also fix some noise issues when switching or turning on the unit.
