No front panel blue gels but there is a rounded and fragile amber gel though behind the meters.Did the Mac 4100 use front panel gels??? I found a gel on the floor in my work area and wondering if it’s from my 4100. I’ve worked on a few Mac’s in the past few months and now I’m wondering if this gel fell out of my 4100 without me noticing.
Thanks…..
Now you only need to think about every other McIntosh you have taken apart in the last year - I think this would drive me crazy. LOLThanks for the response - now I don't have to think about that....lol.
If you still have this 1900, you can of course check and see? Is that a hard job on the 1900 to pop it open and investigate?The gel was green - I think it belongs in my 1900!!! UUUUUGGGHHHHHH!!! lol!
Yep, that's a different take with the Blue Meters.Just an alternate look for a Mac 4100. I used LED replacements and different gels.
I used white LED's, blue lamp "condoms" which fit nicely on the meters and for the dial glass white LED lamps with gels to fine tune the color I wanted.Yep, that's a different take with the Blue Meters.
With the Dial Face Festoon Lamps, and perhaps like you did, I swapped to a Cool Blue 3 Segment LED Lamp and the stock Yellow Gels. I left the stock Meter Lamps and the Yellow Gel untouched. I loved that the LED Lamps were "Aim-able" and could fine tune light intensity for both sides to provide for an evenly lit Dial Face.
This is beautiful, was this achieved with simply changing to Cool Blue Segment LED lamp or did you need to add a green gel as well? If you don’t mind, specifically what would someone need to replicate what you’ve done here? Seeing this I don’t understand why MAC didn’t retain this look on this unit, very nice.Yep, that's a different take with the Blue Meters.
More labor intensive but an entire rainbow of colors could be had by swapping Gel Material, since there's only a limited availability of Lamp Hues-Colors. The proper Gels will be heat-fire resistant. Such gel material is something you don't want to buy from a hobby shop unless of proper spec for lighting applications.
I have a couple Swatch packs on hand. But I won't further operate on my 4100 unless I must, such as a Burnt Meter Lamp., the Gel Cocoon will have to come off first, and there will likely be no salvaging it.
Would I go to LED Meter Lamps? Possibly.
I think they just followed the trend at the time. In the late '70s, many major manufacturers had gone to backlighting in "warm white", leaving colors for individual indicators where they'd stand out better.Seeing this I don’t understand why MAC didn’t retain this look on this unit, very nice.
Elaborate further. Which Lamps within the 4100 are you speaking of needing Blue Lamp Covers? The Dial Face Lamps, or the Meter Lamps? There's 4 Lamps total. 2 for the Dial Face, and 2 for the Meters.Where did you find the blue lamp covers
