Grindhouse80
I've been using it every time after playing a record. Im thinking that's excessive. How often do u guys use it? I lower my cue onto it two or three times. I want my ortofon 2m blue to last cause they're not exactly cheap.
Magic Eraser - How often do you use it on your records?
Safer (IMO) and washable. I have been using the same package for years and finally up to my last piece.I have yet to find a better method for detaching the odd microscopic fiber thread,
Yep, brush once per side and Magic Eraser maybe every 10 or 20 or so.
Moongel stuck to my stylus and turned it blue. I'll never use it again.Safer (IMO) and washable. I have been using the same package for years and finally up to my last piece.
https://www.guitarcenter.com/RTOM/Moongel-Percussion-Dampening-Gels.gc
Just (VERY) gently drop stylus on it prior to playing or better yet after if you see any debris. That and a stylus brush is all I use FWIW.
ME is safe as long as you don’t drag the stylus through it. Down and up. That’s all.
I've used ME sparingly to clean a stylus and I think it works but I've switched over to DAP Blue Stik as recommended by Soundsmith. I use the cue to lower the stylus into the Blue Stick four or five times every few records. Most importantly, I try to start with clean records.
