Given my fervor in discovering that 142 amps do indeed have treble when you replace bad HF filter capacitors, I got one unit running like a champ and the second is now making me fight to get it running correctly.
I have attached a picture of the two misbehaving resistors (511), they like to smoke after you get about 90v on the Variac. I have also attached the schematic. These resistors are found between the 6.3v filament winding legs, then connect to the cathode resistor and from there to ground. Before smoking, there is an audible 60hz hum from the speaker. A 60hz hum is audible with the Variac set at 60v (.1vac measured at the output transformer).
I am sure I have miswired something, I did replace one tube socket and initially miswired it, luckily I miswired a filament wire to the unused pin one. I have swapped the driver and power tube (and tested the existing set of tubes for shorts), no change in the hum or the smoke.
I have included pics of the chassis and the ground wiring due to the 60hz hum being audible
All advice and insights are greatly appreciated!
