blknd_vggs
Welcome to my project thread! Sorry in advance for the long intro, but I feel like some context helps. I've organized the post into sections for easier reading.
- Prologue -
Newbie here with my first major hi-fi stereo project! As such, I want to document my project as I go. As someone who is a long-time tinkerer and diyer, but who's far from an electronics expert, I hope this thread can be a resource for anyone else considering a similar project! My goal, outside of having a working restoration and upgrade of this Maggie, is to get more confident in this hobby, understand things conceptually, and have some good nerdy fun.
- Backstory -
I've been slowly restoring a lovely Magnavox 2st660s console that's in the possession of my partner as a family heirloom. The console has a 57-12-00 tuner, 93-02-00 amp, micromatic turntable, and utilizes a pair of horn tweeters with 15" woofers. For some time, the console played alright, and per my partner's father, it had been serviced "recently" but certainly showed signs of age when listening to it (using FM radio and tape/aux input from 1/8" to RCA, but the turntable does not function...for now).
After my partner and I began using the console more, I noticed the audio levels in each channel were not balanced. Also, the pots on the preamp/tuner we crackly... to be expected for a unit that was seldom used. I gave the pots a light cleaning, which seemed to help. Then, after some more use, the audio output started to crackle, scratch, and pop at random times until it became far more frequent... Most recently, after the system warms up a little (less than a minute or two), the crackles occur and remain until I power off the unit. These crackles are loud, persistent, and independent of the volume level. The sound is hard to describe, but it seems like the distortion "surges" or "rolls" through the circuit. I began to suspect that the "recent" servicing her father had mentioned was either not so recent or not so thorough.
I opened the console up to see what I could find. The 9302 had not been touched since it was made in the 60s. The tuner does appear to have some newer components (to my relief!). So I scoured the many threads about the 9302 and while I'd love to tweak, tinker, and improve upon the original design, I figured I'd start with simply restoring the amp to near original spec... Well, that plan has now changed a bit...
Some pics of the amp before I removed it. NOTE: A lingering concern I have is what appears to be staining from melted transformer potting compound?? I would assume it must have been running rather hot for this to happen... I'd love an explanation if anyone has any clues.
- Restoration Begins -
For the 57-12-00, I've not touched the tuner aside from dusting and thoroughly cleaning all of the pots, power switch, and selectors since those were all scratchy and sticky. No more issues there after cleaning.
For the 93-02-00, I first cleaned the balance and hum pots thoroughly and then replaced all electrolytic capacitors with modern equivalents. Then I went through and cleaned the tube pins and sockets. For all pots and tubes I've stuck with Deoxit D5. After hooking up the amp to test my work, the crackles persist. I confirmed all solder connections... no issues there.
9302 with replaced electrolytics:
- Narrowing Down the Problem -
Without any testing equipment, aside from a decent DMM, I think I've narrowed down the issue to it being related to something along the Channel 1 circuit:
1. I flipped the left-right speaker connections to see if the crackles would follow and they do.
2. I've swapped the 6eu7's around (V4 to V1) - no changes
3. Flipped the 6bq5 pairs (V2 and V3 swapped with V4 and V5) - no changes
4. Amp voltage testing with the tuner and amp removed from the console but hooked up to a 4 ohm dummy load - I confirmed weird voltages along the channel 1 circuit
5. I do not have a way to test the tubes, but no red-plating has been observed. A gentle tap of the tubes during operation reveals no harmonics as far as I can tell
6. Wiggling one of the 6bq5s in the channel 1 circuit did produce a similar and exaggerrated harsh crackle - hmm
7. Tightened all contact pins in the 9 pin tube sockets and even the octal (just for the hell of it) - no changes
- Current Project Status -
After realizing I may need to replace tube sockets and everything soldered to them, I figured it may be easier to just gut the chassis and start the build from nearly-scratch. Admittedly, I also couldn't stop myself from wanting to give Dave Gillespie's 9300 mod a try. Still, I wanted to keep this console as stock as possible. In another thread, I posted inquiring about whether this is even possible? Would the upgrades play well with the stock tuner and horn/woofer setup? Consensus from some AKer's who have experience with the Dave's 9300 mod believe it will, but the stock speakers and their current crossover setup may leave me with more to be desired. New crossover coming down the line?
For now... we move forward with the Dave's latest mod update from 12/2025! Since I'm going to be starting pretty much from scratch on this build, I'll be replacing all resistors, capacitors, and tube sockets. The hum and balance pots will be switched out for the EFB pot or resistors, respectively. Transformers will remain stock and I will not be doing any of the bucking mods since I will need to use the wiring harness.
To help me better grasp how the mod schematic maps with the actual wiring of the amplifier, I took some time to "port" over the modded schematic to a SAMS schematic for the 9300 series amps. I'm pretty proud of this haha, but I would greatly appreciate it if someone can check my work! I'm having a hard time figuring out how the second channel output tubes are connected so that I have two bias test points (one for each output channel). I know I need another 10 ohm resistor to the cathodes of these tubes... Please advise!
Dave's 9300 mod on a SAMS schematic:
Link to Hi-Res PDF here!
Any and all suggestions or advice are welcomed and appreciated! More to come...
- Prologue -
- Backstory -
