daftnytes
I rebuilt the crossovers and the 9306. I completed the crossovers first and tested them with my 8601 and it sounded really good. I haven't had speakers efficient enough for that amp for a while so it was nice hearing it again. I kept the specs of the components identical to what was in there. For the amp i replaced all resistors with 1% metal film and I replaced all caps. The plastic insulated hook up wire was starting to crack so i replaced all of that I swapped out the can cap with a new one. My 140 watt soldering gun didn't do a great job on melting the solder around the mounting tabs. the rectifier tube and one of the 6bq5s tested a weak so I swapped those out with some tubes i had around the house for bench testing. I first tested with no tubes, followed by a dummy load with tubes, and then a speaker test with a portable CD player. I had sound in both channels but i had a high pitch noise on warm up followed by motor-boating. After some digging on the forums it turns out i needed to add some 390ohm resistors to each channel to since i was bypassing the balance control that connects to the other side of the wiring harness. I had some terminals around so i made jumpers for the resistors instead of soldering them in. I have the amp back in the console and I really like the sound. I have some NOS Soviet 6bq5 equivalents in there now that sound pretty decent after they burned in for 16 hours or so.
My goal is to have this thing restored as close as possible to the way it was originally after that I'll look at mods for the amp. Going to work on the mpx and tuner next.
