Magnavox Micromatic TT
Butch65
anyone know output per channel on a mid 60's magnavox micromatic TT in console with radio. I would like to attach external speakers. Thanks.
Too many variables/different models to say without more information. Speaker impedance will probably be 8 ohms. Power output, if using 2 6V6GTs per channel then about 10 watts per channel.
Thanks. The specs on the speakers require 20 Watts each minimum. Would another amp fix this? As you can tell, I know just enough to get in trouble.
Try it anyway. This is really a suggested power level to obtain a certain sound pressure level. If it's loud enough for you then it doesn't matter.
