Maranta 45 Adapter
ehc68
My SX-1050
Marantz 45 Adapter
Does anyone have a Marantz 45 adapter with an overhang gauge?
Actually any adapter with an overhang gauge would be great, but
was searching for a Marantz and have had no luck!
Set the distance from the stylus tip to the rubber gasket on the headshell connector to 49mm. Then you won't need to fuss with trying to measure overhang. It will give you the same results and is easier to do.
Wade
Wade
Thanks, that worked out great!!!
Measuring overhang by using the spindle or 45 adaptor has always struck me a bit odd. I mean if the turntable is fully manual it works pretty well but many semi or full automatic tables don't like to have their tonearms moved over the label. The 49mm headshell method (of course potentially different for other tables) makes more sense.
