David_NC
I recently shipped some components from my house in NC to CA. One of the first things I sent was a 1060 integrated amp. Cosmetically, this unit looks to be maybe a couple years old. When I hooked it up before shipping, it had really sticky pushbuttons and noisy pots. Those cleaned up very nicely with some Deoxit and now work perfectly with no noise or dropouts. I hooked it up last night to a pair of Dahlquist DQM-9's in the garage, and it sounded great. A friend was over and was impressed that something with 'only 30 watts' could sound so good with deep bass.
. I listened to it for a couple hours, and my IR thermometer was reading 2-3 degrees above ambient (in this case, random parts of the chassis and faceplate); it really runs cool.
I'm happy with its sound but would like to do what's necessary to keep it from being damaged due to old caps or other components and OK to use regularly. Eventually, I'll do more, but for now, I want to make it safe to use. I've got four more pieces of gear that will be shipped, and I don't want to get too bogged down in any one unit and would like to make them all at least usable. So, what areas do I need to concentrate on, in terms of replacements. It's all original, from what I can tell, and no caps appear to be leaking or swelling. The power supply board looks to be really simple, and the only boards that look complex are the amps themselves.
(below is a pic of the other 1060. It appears much older than the one I have here (its serial number is 1429). Otherwise, they seem identical other than the older one having an engraved faceplate, all black speaker connections vs the red/black ones on this model, and has a support running front to back on each side, and the newer one has black filter and coupling caps.)
time!
