met_engr
Happened across a Marantz 1120 for sale by chance yesterday. Previous owner told me it had some channel balance issues and a scratchy volume pot so I'm cautious to let it drive my speakers since I only have one set currently.
I've had some vintage stuff in the past, but nothing I'd invest much time fixing. I think the Marantz is worth the effort so I took a $ chance. Could use some advice on what I should test, clean, fix immediately before hooking up my speakers...and then things to consider down the line.
So far I pulled the jumpers on the back and used the preamp side only. I ran my turntable in and the preamp out to my main system.
I noticed a couple of things playing around today:
- The volume knob was only slightly scratchy. Optimistic a slight cleaning is all it needs.
- No discernible channel imbalance, but the balance fader needs some work. Sounds ok at the mid-detent. Every other position loses a lot of gain.
- EQ actually works, but there's crossfeed (I think that's the term). If I adjust right side base, both sides increase. If I adjust them together the whole system (left and right) sounds equal.
- High and low limiters work well.
The phono stage sounds really really good for what it's worth. I'm eager to get it fully functional now.
