Blue Shadow
Waiting for Vintage Gear from this century
I don't think enough 1120s have been done to verify SM accuracy.
Get a list from the SM and compare it to what you have in your unit, order what you have in your unit.
Most new caps will be way better than the old electrolytics in your unit. So what to use is up to you but it took me 8+ years to adjust to the caps I like and are recommended for better performance.
Film caps instead of low value electrolytics.
Nichicon PW and HE and Panasonic FC and FM are good all around caps
Vishay/BC Components AML 138 are good axial caps.
and more and more.
Nichicon has a line of about 8 different audio grade caps for signal path uses.
Too much to learn
So build your list and post it and ask for comments is the best I can recommend. Reading 8+ years of old recapping threads is too much to do for this simple recap.
As to searching Mouser, first figure out what you want, axial or either axial or radial for each cap and then select that when drilling down.
Me, I'm gonna use whatever and the unit will sound new again.
and more and more.
Too much to learn
in a first recap.Being a novice I'm concerned I'll choose the wrong capacitors to be honest. Thinking this is a learning opportunity though.
