Guy, probably best to start your own thread with your questions. I'm about to start on the same model amp so I'll be doing the same
Good Luck with your amp
Rob
Yeah you are right. I will a do new thread. This one could be huge !
Rob
PE01 Tone Control Board = Done!
Here's what I started with:
As shown above all 4 of the push button switches and the selector slide were pulled from the board, pulled apart and cleaned. All capacitors (electrolytic, film, ceramic) and all transistors were replaced with modern equivalents.
Here is the end result:
And here are the details. None of the original parts were failing or damaged. Replacement was a personal choice. The only real change in spec was the local DC filter and that was increased to provide the best possible ESR/ripple rating in that position. I also thought the cataloging of the board could help future techs looking for details on this unit.
CE01/02 - 50v/1uf low leakage electrolytics [manual error says 0.47uf] were replaced with Panasonic ECW series polypropylene films. Plenty of space for these nice films on the upper right.
CE05/06 - 50v/4.7uf low leakage electrolytics were replaced with WIMA MKS2 polyester films.
CE07/08 - 50v/200pf ceramics were replaced with Kemet 5% C0G ceramics. 220pf was the closest available value. Important to try and stick with 5mm leads here. Makes installation so much easier.
CE09/10 - 50v/1500pf films were replaced with Nichicon QYX series polyester films of the same value.
CE11/12 - 50v/5600pf films were replaced with Nichicon QYX series polyester films of the same value.
CE13/14/15/16 - 50v/0.018uf films [manual error says 0.033uf] were replaced with Kemet MMK series polyester films of the same value.
CE17/18 - 50v/6800pf films were replaced with Nichicon QYX series polyester films of the same value.
CE19/20 - 50v/0.047uf films [manual error says 0.47uf] were replaced with Nichicon QYX series polyester films of the same value.
CE21/22 - 50v/3.3uf low leakage electrolytics were originally slated for Panasonic ECW series polypropylene replacements. Plenty of space to the left of the sliders but I apparently forgot to order them so used WIMA MKS2 polyester films I had on hand. Still a quality replacement.
CE25/26 - 50v/1000pf films were replaced with Nichicon QYX series polyester films of the same value.
CE27/28 - 50v/0.1uf films were replaced with WIMA MKS2 series polyester films of the same value.
CE29/30 - 50v/0.015uf films [manual error says 0.027uf] were replaced with WIMA MKS2 series polyester films of the same value.
CE31/32 - 50v/0.082uf films were replaced with Panasonic ECQ series polyester films of the same value. These were chosen because the lead spacing is larger in this position. The leads still need to be bent but there plenty of extra on the Panasonics.
CE33 - 50v/100uf electrolytic [local DC filter] was replaced with a Nichicon UPW series [low esr, high ripple current] electrolytic rated at 63v/180uf.
CE83/84 - 10v/100uf electrolytics were replaced with Nichicon UPW series [low esr, high ripple current] electrolytics rated at 16v/100uf.
CE85/86 - 50v/40pf ceramics were replaced with Kemet 5% C0G ceramics. 39pf was the closest available value. Important to try and stick with the 5mm leads here. Makes installation much easier.
CE87 - 50v/22uf electrolytic [board polarity markings reversed!] replaced with Nichicon UKL low leakage series of the same value.
CE88 - 50v/0.47uf electrolytic was replaced with WIMA MKS2 series polyester film of the same value.
QE01/02/05/06 - 2SC1222 to-92 transistors were replaced with Fairchild KSC1845FTA's. Same pinout. Gain matched.
QE03/04/07/08 - 2SA750 to-92 transistors were replaced with Fairchild KSA992FBU's. Same pinout. Gain matched.
C701/702 - 50v/100pf C0G ceramics [manual error notes them as film said:. Even though these were already C0G ceramics I replaced them with the same because modern replacements are about 1/10 the size. Less chance of the big floppy disc getting pushed around in the future.
