Richs_Trains
Well-Known Member
Hey all. Thanks for all the help on the 140 and 170dc, next from the closet is a 1180dc. I have unboxed it, tested it, and removed the covers. The unit plays well and all controls operate. This unit uses boards with pins that are prone to failure and someone before has solder bridged all the pin connections in this unit. They have also replaced all the outputs on one channel. It also appears that the relay has been replaced. My goal on this one is to re-cap the power supply, power amplifier, and replace the filter caps. About 50% of the long soldered in board is accessible, so I will try to replace as many of the electrolytic capacitors that I can reach. I will also be replacing the mica insulators and thermal compound on the outputs. Some of the solder connections on the power supply look questionable, so I will re-do them also. I will probably need help along the way and hope there is someone familiar with this unit to guide me along. Thank-you! Rich
