Marantz 1180dc re-cap help/advice/insight
Also, I believe in a "burn in" process. Hopefully, you can let it play for several hours. My experience is that if there are any further problems that need to be addressed, they may present during the burn-in.
On mine it drops to zero.
IIRC it starts out at around 20~30mv at power up, then goes down to zero.
Did you put in higher value filter caps?
I recall that being the case for me
Thanks for the info, mine's closer 8 seconds. Found a pair of KLH speakers at the thrift store today. Make sure they weren't frozen or shorted and hooked them up. They sound much better than the 4-inch JBL's I've been testing on. Going to let it run awhile. Rich
Hi Everyone,
Regarding the fragile board connector pins in the first post of this thread, I've just acquired one of these where literally every one of these is either bent or broken. Someone really went to town on it.
Are there replacement pins out there or is the typical repair to create solder bridges?
@Marantz6G, are you talking about the wire wrap header pins? If you want to replace these, you can order something like this and solder them in. Digikey or Mouser should carry them. They come in different #rows and pins. You need to look at the pin spacing and head/tail length.
