mazinkaiser
That looks like your bridge rectifier that converts the transformer AC to DC before the filter caps. I do think you have a big grounding problem with those big caps.
Im thinking the same thing would i have to build a new bracket so that the entire thing is a ground bracket like the original or would adding another thicker gauge wire ground from where the missing factory bracket was and solder it to current metal plate that is sitting between the two negative lugs on the caps do the same thing?
