Marantz 2015 Balance slider and missing channel...
special_20
I picked up a cosmetically minty looking Marantz 2015 this morning. Unit was advertised as having some issues: missing right channel and lights out. Bought it hoping it was dirty pots or maybe a bad capacitor. This one however has me a bit stumped. Unit is clean inside and out. No obvious part faults internally. I deoxited the controls and pots and switches work with no static or crackle in the working left channel. The balance switch does seem to not go all the way to right.
Hifiengine has a manual however, it's pretty sparse on details though. Based on schematic and info gleaned from threads here at audiokarma, the amp section appears to be working. I am getting the voltages listed in the service manual off the 4 output transistors (~23v for each) and I was able to adjust bias (7.5mv) and DC offset (~0.1mv) for both the left and right channel. So I've got juice, which means I'm not getting signal.
Seems like my problem exists somewhere between input and the amp. Tone controls seem to work fine; likewise switches seem to be fine - no pops or static in good channel when playing with the knobs and switches. As mentioned above, fader doesn't move all the way through it's mechanical range.
I'm hoping someone has some tips on how to trouble shoot this. Am I right to suspect the fader? Is there a way to test it by measuring resistance through the range? Is it worth taking apart and inspecting? Tips and suggestions appreciated. Hope to get this girl singing again!
Thanks in advance!
I would suspect something may be wrong with the balance slider. It should function mechanically and if it doesn't there's an issue. Nail that down and it may resolve the missing channel. If not, 1 down and you can rule it out.
yup, bad switch. Contact had fallen off and was jammed into a corner. I was able to salvage the switch. Doesn't appear that anyone make a 250kohm stereo slider switch so I got lucky. I made a gallery on Imgur.
Thanks Bryan12v! It's a decent little amp given it is all of 15 watts. After the repair work and an audition, I decided it was a little underpowered for my tastes and current stable of speakers. I've passed it along to a new owner who's happy to have a vintage Marantz of their own. I left it better than I found it :)
