Everything has been de-oxit and work smooth and have no effect on the sound problems. A couple resistors have gotten hot enough to discolor the board and one transistor has discolored the board where the pins go through.Have all the tape monitor switch, speaker switches and selector switches had a couple good cleanings yet?
Beamer, where can I find these, SM shows them as 3 watt 0.5 ohm and I don't seem to be able to locate them. I would like to change all four along the back. Thanks RichThe two big .5ohm (?) resistors on the right side (channel) look toasty.
and probably can only finish the 4230 (just a re-cap) with my limited abilities. I might have a chance with the 2015 and 3205, but only with the help of AK. As lost as I am trying to work on the power amp boards, the tuners are just 'no man's land' for me. Thanks for the help!Right now I have four units in various states of completion
You just need to test them. If they test good you don't need to replace them. I found some on Flea Bay they were 5 watt. You can use 5 watt .5ohms. Don't replace if there is no need to. Hang in there you will surprise yourself with your talent. I might have some left over not sure of the value or quantity but I won't be home for a week. I will let you knowBeamer, where can I find these, SM shows them as 3 watt 0.5 ohm and I don't seem to be able to locate them. I would like to change all four along the back. Thanks Rich
Thanks Steven, will at to my cheat sheet!According to Echowars post, testing PNP with a diode tester is the reverse of the NPN. Negative lead on base and positive on emitter or collector should read a diode drop. Positive on base and negative on E or C should read OL or no conduction.
