ringading
Well-Known Member
I am restoring a 2220 I picked up for $50 off CL. Cosmetically it is in mint condition. It had horrible static in both channels and a very low right channel but recapping the P700 board took care of that. Sounds clear and clean now!
But of course as happens on these old units, something else cropped up.
I now noticed that it won't do stereo in FM - no stereo light. I replaced them both with the proper lamps (thanks dgwojo) and they work great in aux or phono.
I read a thread (http://www.audiokarma.org/forums/showthread.php?t=157920) about adjusting the trim pot on the MPX board for a 2220B that solved the problem for a couple of folks. However the board on the 2220 is different. From comparing the two SM it seems that it is the R304 trim pot on the 2220B and the equivalent on the 2220 is the L303. Does that sound right? Getting a little :thmbsp: or :thumbsdn: from the great folks here would go a long way.
Anyone else run into this problem? I know a full alignment might be in the cards or the MPX chip might be the kaput but I don't know if that is replaceable or not.
FYI - I am no repair tech with no formal training, just learning my way through by reading through all of the great posts here.
