Bert 1100
ALSO, I can't find 47uf 16v but the service manual says +100% -10%
Could I go for 47uf 25v. Assuming I could. Its within range with a tolerance of +/- 20%
The +/- 20% concerns capacitance, not the voltage rating.
But yes, going with a 25V instead of a 16V is just fine, maybe even recommended in some cases.
The voltage rating is what the cap will be happy to see at most. So even a 100 volt cap instead of a 6.3 volt one will work, but the size will be too big and if in the signal path that might have some negative effects.
