Mat86
Not sure how long it's been like this, but I've always felt these speakers didnt have good bass so I'd compensate with tone controls, but this weekend I decided to sit down and measure both with a sine sweep on an app and I was shocked when everything sounded fine. But, I was using my laptop and DAC to test it on the AUX input, not my usual turntable.
So I went back and put on a record and noticed immediately that one channel just sucks. Its tinny and has no bass, may as well be an old computer speaker. The other channel sounds great.
- Switching speakers makes no difference, its whichever Left is plugged in to
- I swapped the speaker cables around. The right channel output to speakers is always good, left channel sucks
- I also swapped the RCAs on the turntable, so its not the source. I also swapped the RCA phono inputs over, so it's not the jacks or cable either.
- I tried with both main and remote outputs
- Headphone output seemed consistent with the issue
I should also mention that I recently recapped the phono board, but my suspicion of the channel imbalance goes back several months before tinkering. When I had the unit serviced a couple years ago, the tech didnt notice anything (but probably didnt check)
measurements (just played the beginning to Ai No Corrida to test bass response, not a full sweep). You can clearly see the red line on left fails to get very high below 100Hz (ignore yellow)
If it's not the cables, source, or speakers, and not the amplifier itself (since AUX works), what's going on here? Phono equalization broken?
