MARANTZ 2230 LOW FILTER SWITCH CAUSING LOUD POP
PROJECT 2501
Engaging/disengaging Low Filter switch causes loud popping noise through the speakers. Regardless of the position of the volume dial the popping noise is audible and unaffected by attenuation. I have verified that this is an isolated issue with the low filter switch and only the low filter switch.
Would this indicate failing capacitors on the preamp tone board? Does the manipulation of the low filter switch discharge DC from the capacitor which momentarily finds way through my speakers?
To my dismay, I would imagine that the issue is unlikely caused by a dirty switch and the solution to my predicament will require attention of which a $15 bottle of stereo sauce is incapable of providing.
Please advise.
I'm with Pat (as usual) that a noisy switch is the issue. The caps involved in the low filter circuit are on the filter board, not the tone control and are .047uF. That won't pack much of a pop!
Greetings,
Did you ever resolve the popping issue from the Low Filter switch? What was the actual cause?
Thanks,
Jim
Hey Jim, I thought you had a 2230, and most times that is the fix. Since you are now saying you have a 727, I would guess it is one of the bad blue Sanyo caps. You may want to post in the Pioneer forum?
I do have a post on that forum as well, I just ran across this one accidently and figured I'd inquire, but hey, thanks for the advice. I will change the blue Sanyo caps as you directed....Hope that remedies the problem.
Thanks again,
Jim
Thanks everyone for your very helpful advice, replacing the blue Sanyo caps remedied the noisy switch issue.
Thanks again,
Jim
Pat... :eek2: I am the original owner of a Pioneer SX-626. The only two parts replaced besides bulbs? Those Sanyo caps!!
[Q UOTE="rBuckner, post: 9681704, member: 68225"]Pat... :eek2: I am the original owner of a Pioneer SX-626. The only two parts replaced besides
bulbs? Those Sanyo caps!![/QUOTE]
The 626 is a cap coupled beast, I use one in my testing area, still ticking!
De-oxit did not fix the problem...
I believe capacitor C754 has gone open. I have a loud channel....preamp is steady but left power amp is on the fritz.....
The 2230 is still used in my main rig though...
I have it controlling a model 32 and it's performing well as a dedicated preamp...
