Hello AK'ers.
Well. i was in the measure moment when r771 of good channel EXPLODED in an impressive way... i was checking voltajes on h756 (a606 sub w/2n5416) an accidentally i touched emisor and the metal case with the VTM tip, then R711 set on fire.......
my readings before that short happened was:
P750, LEFT CHANNEL (THE "GOOD") VOLTAJE, DBT CONECTED . NO SMOKE ON R771.
j764-62 -----0v
j579 ----- 39.2
J761-----0.6
J760 -----39.6
J758---- 39.5
J756-----57.5
J757-----40
J755,63-----58.3
P750, RIGHT CHANNEL (THE "BAD") VOLTAJE, DBT CONECTED . NO SMOKE ON R771
j764-62 -----
j579 -----
J761-----21.8
J760 -----31
J758---- 31.3
J756-----52.8
J757-----31
J755,63-----57.6
H755, C959 SUB W/2N3440, LEFT CHANNEL, DBT CONECTED
E----- 58
C------58
B-----42
H755, C959 SUB W/2N3440, RIGHT CHANNEL, DBT CONECTED
E-----52.2
C------57.3
B-----36.7
H756, CA606 SUB W/2N5416, LEFT CHANNEL, DBT CONECTED
E----- 40
C------0.6
B-----39.4
H756, CA606 SUB W/2N5416, RIGHT CHANNEL, DBT CONECTED
E----- HERE R771 EXPLODED. END TEST.
C------0.6
B-----49
H755, C959 SUB W/2N3440, RIGHT CHANNEL, 120V PLUGGED UNIT
E----- 69
C------69
B------53
WITH 120V, C007 feeds the boards with 69v on positive (red), 0v with negative (white).
r771 after the short.
At this point, I've changed -almost- all the pieces in both boards, rectifier bridge i guees is OK because c007 feeds 69v to both boards..... the only suspect is the set of TO-3 transistors....... all of them are news, MJ15024 "ORIGINAL OEM WITH WARRANTY" I bought here in a famous electronic store in Mexico...... i bought about 15 mj15023/24 in order to have stock fore the 2235b, 2385 and the 2230 on this post.
i will delay this repair/upgrade until the new output transistor arrives.......
in a personal note, it is unveliablable about 8 mj15024 were bad... even for OEM or fakes transistors it is a high ratio.....
THANK YOU SO MUCH FOR YOUR KIND HELP,
ONCE NEW OUTPUT BE WITH ME, AND I HAVE DONE THE RECAP ANT REPLECEMENT OF TRANSISTORS, I WILL POST THE RESULT HERE.
REGARDS!!!!!!
