Here's an interesting one. I've got an early 2270 that's blowing fuses each time it's powered on... Unless I remove the top outer transistor on the right hand heat sink then it powers on Ok and I can hear some poor quality sound via the headphone output, but nothing through the speaker cables. It's a mystery, I've tested all other components on the output board and it all tested fine. Changed the transistors with new ones and same result. Any ideas where I could look for the culprit?
