Bluefisheye
After few weeks, I just finished to restore my Marantz 2270. I recapped all capacities, replaced several transistors, diodes, blue switch, speaker relay and relamp all bulbs, lamps. At the end, I had a problem with popping crackles in the right amp board and without the volume potentiometer being activated when I switched on. After checking the preamp board, the popping crackles were due to transistor H753 which was defective on the right amp board. Once changed, everything works perfectly the sound is awesome and and very well balanced.
Let's go for the next project, a Marantz 1030 to restore
