Steven Tate
CEO Flat Forehead Soc.
i've started a rebuild on a Marantz 2275. Started with power supply P800 board. I have stripped the electrolytic caps and removed the protection relay. There is a TO-220 case transistor on a small heat sink that is a 2SD331. It may have been hot because there is a lot of brown flux or something around the terminals on the bottom side of the board. When I did my 2325, I found a recommendation from Catrafter to replace the pair of these on the PS with MJE15030, which I did and which worked well. Now... at another place on the 2275 board there is a mounted 2SD330 transistor with no heat sink. Doing an AK search, it seems the same MJE15030 is also the substitute for this transistor. So... the question is, is that same transistor a good substitute for both the SD331 and the SD330? And would any of the experienced guys have an opinion whether I should replace them or not? I happen to have a pair of the MJE15030's left over from my 2325 build. I just didn't see any recommendations to replace these in any of the 2275 rebuild threads, but the possible evidence of heating causes me to want to get some good opinions on this. Thanks!
Steve
Steve
