...It takes about the same amount of time to clean and apply new thermal compound to the old one as it does to install the new device and compound. The cost is less than a buck and a half.
Mr. Catrafter, I agree with you
but I have to admit that I was a bit hasty in my previous post so I have to correct myself and give some additional explanations (because english is not my native language I apologize in advance for all mistakes I'll make).
We all know that each transistor is described with lot of data which are called
Product Specifications.
Electrical characteristics are part of overall specificatons and consist of many parameters and conditions. The best known of these parameters are:
- Vcbo - collector-base breakdown voltage
- Vce0 - collector-emitter breakdown voltage
- Veb0 - emitter- base voltage
- Ic - collector continuos current
- Pc - collector power dissipation
Above parameters are not the only ones, there are more of them like
saturation voltages,
cutoff currents,
capacitances,
biases,
safe working area,
bandwidth... and
DC current gain (Ic
/Ib
ratio, hfe
Actual circuit gain depends on other components too, not only transistor. But if the original transistor has a high gain, we'll try to match it. Additionaly, current gain falls off at higher frequencies, so a high-gain transistor can deliver a wider frequency response than a low-gain transistor.
Let's take a look, for a moment, at the Marantz 2275 schematics, P800 board. Above the board's schematics states: H801 -
2SD330 (
D.E); H804 -
2SD331 (
C.D.E.F). What's the meaning of these letters?
They desribes
DC current gain (hfe
) as follows (
min-max):
- C 40-80
- D 60-120
- E 100-200
- F 160-320
It's well known that these transistor are discontinued and hard (better says - unable) to find, even 2SB514/515, their substitutions, too. Then we do some web search and find a transistor cross-reference web page. Finally, we populate the web page form with above parameters, press
Search and the result is about 800 - 1,000 transistors which are suggested as replacements! That's not true. Only one (if you are lucky enough) is a
substitute, one or two are
nearest preferred replacement and that's that. Again, if you are lucky enough.
What about MJE15030? If we take a look into characteristics, we'll see that it may
barely replace 2SD331 (because of low
hfe) while it cann't replace 2SD330 because of
insufficient hfe.
In my previous post I wrote that TIP31A is nearest preferred replacement for both of them. That's partially correct. With
hfe from min. 25 to max. 50 it may
barely replace 2SD331, not 330.
Luckily, there is a manufacturer which has a compatible part. The manufacturer is
NTE and the name of the part is
NTE152. It's a power amplifier silicon complementary transistor which will perfectly substitute both of 330/331. With
hfe from 40 -
200, Vce0=
90 V; Ic=
4 A, Pc=
40 W... and other parameters, it's better then genuine ones.
Mr. Catrafter, that's why I'm thinking that MJE15030 is not enough good replacement for both 330/331.
The post is a bit large, but I hope that this will help. Regards...
