MARANTZ 300DC HELP.
jFF_Bulbo
Hello AK'ers.
i've finished the recap & restoration of my 300dc. abnd some problems are present.
unit power on, relay clicks and it sound. DBT (100w lamp) shine i think so much.
when connected to 120v, powers on, relay engages, and soun is present, but..
-DC OFFSET is 20-30mv on lef channel.
-dc offset is 1.1v on right chanel. both channel has te "gain" knos at maximum.
well. the unit reaches 39°c in both heatsinks after 10 minuts. is this too hight temp?
-when i tried to adjus vumeters, right channel has a bad response.
-i measure the RMS volts in both channels with gain at maximum. i measure 11.44Vrms on left and only 6.00Vrms an right chanel. I put a 1khz vpp signal trought the rca imputs of the unit.
well. i recaped it including the main cap (cde 15000uF/100V)
i follow the Audiokarma transistor guide to substitute all the transistors in the unit, output are mj21195/96. all from digikeys/newark.
important. i did´nt find the 2SA789, neither their replacements (ztx957), i used 2SA1370 instead. bad idea?
well. finally. when set the inpout in "dc coupling" the relay protect teh unit when gain in right channel is about 1/4. left channel dont have this problem. in the other hand, wheb AC coupling is selected, both challes can reach the maximum gain....
than you in advance for yourt help.
