Marantz 3300 stereo selector mod
might want to make schema sheet before after and tuck in the box cover somewhere?
so is the plan to just make the L+R stereo, too ?
That's a good Idea about the schematic, the Idea was to make it just stereo, no L+R, no reverse stereo etc.
Before you get into it... does the owner completely understand the other sw positions won't work but the switch will rotate?
Yes, I made it very clear that it will basically be disconnected, it will be just for show. I also told them that we should just leave it as it works perfectly.
In the interest of maximum avoidance of present and future loss of value, if it were my Marantz (had a 3300 long ago), I would remove the 3/8" nut holding the control to the front panel, move the switch back away from the panel, and install a placebo switch in the existing hole. Then lash the original switch to something to prevent its flopping around. Or come up with a temporary bracket to hold it.
Reversing this would be easy as pie and it would be back to 100% unmolested original condition. I think that model is one best kept original or 100% returned to an unmolested state, as it will likely hold its value or have it increase in time.
As an aside, you could then "prove" that operating the switch had absolutely no effect on the preamp's sound. Just kidding.
I thought about doing this first before looking at the unit, unfortunately the stereo selector knob is mounted to the front board with the balance and faders all attached as well. so I just unsoldered the switch and wired the output to the input wires as suggested in this thread and it worked perfectly. and is easily reversable. though it did take some thought of wire pathing as the balance and tone faders are wired there as well so that they function.
Well, it was a thought. I know what you mean about not being able to deal with the control by itself. I have a Sansui 3300 receiver that could really use a new volume control (99 and 44/100% unobtainium) and a new balance pot. I have Alps pots that could electrically replace the originals. Problem is, neither can fit since they are the black cube shaped types, much larger . Also the original dual 250K audio taper volume pot has the loudness tap, these pots are just not available, and if one surfaces the price is ridiculous.
I've considered disconnecting the balance pot, should not be difficult since it is the type that balances the channel levels by shunting one or the other to ground when rotated. Ironic, as the balancing issue is caused strictly by the worn balance pot.
