MARANTZ 4070 pops when I switch off power button.
Pepos
Hi all, I've a Marantz 4070 the amp is ok and sounds good, but a small trouble is making me crazy: it pops loud when I switch-off power button. Looking at the Service Manual I can't see relais protection so i supposed that some faulty component may be the cause.
Any idea?
Thanks anyone!:beerchug:
Are you running it 4 channels or 2? Do all channels make the noise?
Is the same in 2 or 4 channels a loudy pop comes out, but only when powering-off, each single channel makes this troublesome noise...
I've also checked the output dc offset=Zero
Found snubber solded in the back of AC outlets but seems to be a simple capacitor not a RC network value is 0.22uf 1000volt (this is printed on the component) not a RC network perhaps already substituted? I don't know.
On the schematic i've found Manufacturer part number is BF1040001 that is a RC snubber network. May I substitute it with a simple RC series?
If yes what are the RC correct values?
Thanks.
I think if you want to make your own, a .1uF polypropylene cap of adequate voltage rating in series with a 120 ohm 1/2 watt resistor will work. All-in-one snubbers are made and sell for roughly $10 in the U.S. There are several threads with links to some examples. A search should find them.
Volume is turned down correct?
May try inserting an adapter or headphones into the headphone jack. I know this is welcomed on Marantz 1060's and 2230's I own. Eliminates the thump associated with cap coupled units.
Barney
Before I want to know if snubber is the real problem, so I want to make myself with right RC values. Then i order a new one :)
I post a photo of original snubber (seems to be a cap).
Barney
In your case the thump is present when you power on & when you power off, my 4070 'pops' only shutting off unit.
Probably is the arcing between contacts switch due to transformator inductor that unloads.
Many units just use a cap instead of a snubber.
This is the schematic from service manual. Why values are different?? Modded??
I built my own snubber i used 120ohm resistor and 0.1uf 1000v cap this solution solve 40% of the problem now 'POP' is smooth but present.
Probably using the right values of RC the pop will disappear completely.
Thanks all for replies.
After trying different combination of RC for snubber G001 and replacing C005 cap located across the switch, case remain unsolved.:dunno:
