I got this 4230 and I found out the bridge rectifier was shorted, therefore fuses would immediately blow. I replaced it with a compatible bridge and turned it on with a DBT. The 100W light dimmed but not as much as it does with other receivers such as the 2225 and 2230. The dial lights came on, somewhat dimmed.
Could it be that there is yet another issue down the line that is actually causing the bridge rectifier to fail at some point? I am thinking maybe the filter capacitor (there is only one) may be a problem?
In your experience - with these quad receivers, should the DBT dim as much as the regular stereo units? This is only 30wpc in bridged mode.
Any words of wisdom would be very much appreciated.
