Med-Fi
I've been recapping my marantz reciever one board at a time and powering on between each change I make.
Yesterday I recapped the power supply, and replaced both switching relays. everything powered up perfectly.
Today I replaced both main filter caps. Powered it on and I heard a sizzle, pop, then saw a puff of smoke rising from what looked like the p800 power board. My train of thought is that I somehow hooked up the main filter caps incorrectly. The old caps had no markings to determine polarity, so I just removed them, and installed new filter caps how I assumed they would go. Negative terminals to the common bar, and positive post to the wires. Please look at the provided pictures, and let me know if anything is wrong. Also, if anyone has any insight on what exactly could have fried and caused the puff of smoke, please let me know. Thank you!
I followed the wires on the positive post on the capacitor (supposed to be negative but was incorrectly soldered to positive), and saw no damaged wiring. Followed the wiring to their prospective circuit boards. Looks like the wiring goes from the filter caps all the way to the P700 amp boards, and the p800 power board. My question is, shouldn't whatever semiconductor that is first in the signal path be the one that gets fried? If that's the case it looks like culprit would be either a rectifier on the power board, or a transistor on the amp board. When i saw the magic smoke it was coming from the right amp board/power board area. Both boards were sandwiched together, so I couldn't really pinpoint where exactly the smoke was coming from.
