Love Vintage
Wow .......you have 2 real ones, I’m jealous I only have a copy
It won’t be easy finding a matching one then....but I’ll feel good getting my 2nd one running. Thanks for sharing,The "doors" are known to differ slightly from the faceplate - not much, but usually visible.
regards
freddy
Maybe stringing together 2 or 3 of the 1N4148 would be the replacement if there is not a direct replacement for the MZ2361 & SZ51066K, I could try to hold them tight to the heat sink somehow I suppose.
Does this work? I have the same issueHere is what I ended up doing for the temp comp diodes,
I hope this works ok, If anyone has an idea on how to improve this I am open to it. I used 3 1N4148 for the SZ51066K and 2 1N4148 for the MZ2361. I placed a mica insulator on the heat sink with compound under it and bed them in compound on top of it, to keep the solder joints from shorting on the heat sink. I also bent the terminal strip mounting tab and the diodes so that when I tightened the mounting screw the diodes are held very tight against the heat sink.
Thanks
Terry
Yes it worked for me, that amp has been in use for almost a year now. The trick is to be sure you insulate them from the heat sink so they don’t short out while having good thermal contact with the heat sink.Does this work? I have the same issue
