Aeon_MK
Just being working on this crappy TT... the same issues as many other people indicated, loose tonearm bearings, slipping gears and crazy behaving auto-return. After thoroughly analyzing the operation cycle of the auto-return function I came to a conclusion the electronic control of this particular function is failing, exhibiting a stochastic behaviour. As I have never repaired a nuclear submarine or a 1970-ties computer, I have decided to disconnect the optical electronic gate entirely, remove the gears for the return function and focus on the lift part of the gearing, finding an optimal friction replacement for the gears to avoid slipping. Also disconnecting the Reject button entirely would be nice. What I get then is the same manual operation as with the Manual switch on, with the exception the platter would not start turning until the tonearm is moved from the parking position.
Should the electronically controlled lift fail again, I would replace it with a manual one, these can be easily obtained from Aliexpress or the likes.
The loose tonearm bearings is then another story.
JustThe microswitches are all working and I cleaned everything with isopropanol. Not going to waste any India Pale Ale on a turntable, I use that to solve my other problems.I can see the cams, wheels, idlers, etc all moving in both directions when the motor direction changes back and forth so I don't think slipping is the problem. Worth double checking though, so thanks for the suggestion.
