Weeks ago, my Marantz 8B turned to red plate (EL34 V4A) suddenly while listening to music. The fuse blowout also.
I found that R20A 100 ohm resistor was burned, I replaced it with a new one. The music plays again for about 5 minutes. The El34 V3A turned red again and the fuse blowout again.
I checked that the selenium diode was open circuit. So I replace it with 1N4007. I adjust the bias, however after 2 minutes the El34 V4B start getting red. I switch off the Amp and take four EL34 out.
I measure the bias is -50.5 volt.
The voltage in between R31 & R32 is 470volt instead of 408 volt.
The voltage on the other end of R32 is 450volt instead of 390 volt.
Are these voltages normal or too high?
Can anybody help me to fix this problem? Thank you so much.
