The Variac arrives today. I follow your instruction to measure the DC voltage with Multimeter Black Probe on Ground and Red Probe on Pin 5 EL34, but the pin goes to left direction as it is a negative voltage, so I have to change by Red Probe to Ground and Black Probe to Pin 5 EL34 for measurement reading. The result is as below:
Turn the output of the Variac to 10v AC
A1 - turn the knob all the way to left - it reads -3.2V, then start to turn from left to right - the reading drops to - 2V on the right end
A2 - turn the knob all the way to left - it reads 0V - when starting to turn just a little, it jumps to -3.2V immediately - when turn it to near the right end, it drops to 0V - then I turn it a little back to left, it shows in between -2V ~ -1V (unstable)
B1 - turn the knob all the way to left - it reads -3.1V - then start to turn from left to right - the reading drops to - 2V on the right end
B2 - turn the knob all the way to left - it reads 0V - when starting to turn just a little, it jumps to -3.2V immediately - when turn it to near the right end, it drops to 0V
Hopefully this information can give you some ideas on the amp's situation.
By the way, Is there any way to check the transformer is good or
By the way, Is there any way to check the transformer is good or not?
May I know what is the next step that I should check? Do you think that should I replace the 5 K Ohm potentionmeter?
