Marantz 8B Resto
-Had one tube red plated first time I fired it up after recap. It has been sitting for a year without use during recap. Moved the tube to see if it was socket or tube and it hasn't done it again. Run it 3 times for maybe 15 hours since and cant recreate it. Put some surgical tube over top of pots and filled it with contact cleaner working the pots hoping to get some down there. No idea if it helped. Socket tension seemed good and no DC leaks from the Goodall caps.
Very nice resto choice in amps! :thumbsup:
My bet is a poor tube contact after it sat in the same socket for a long time. The contact isn’t hermetic, so dust and oxidation can build up over time in storage.
I’d use a good contact cleaner on all the sockets, tube pins, and any other connections — if you haven’t already. Work it in a few times by removing and inserting the tubes. Be careful not to bend the pins. I like DeoxIT D100L, but any good electronic contact cleaner will work.
Good luck with that amp!
Ahh that's probably it. Until Im confident in no more red plating I have some old tubes in there I mostly retired long enough ago my memory of them is fuzzy. I keep them as sacrificial for amp projects as they work well enough for that. Once I put a resistor on bias pots Ill put in matched quad of new tubes and try again. Appreciate the help as always.
If they make 30 watts they aren't that tired. The set i got with my Rauland amps are so done the amps make about 7 watts, they make a solid 40 with good tubes
